Visitor edhalferty
Arty LWIP example BSP failing to compile in SDK -
I'm having an issue following the example here:
https://reference.digilentinc.com/learn/programmable-logic/tutorials/arty-getting-started-with-microblaze-servers/start
(Sorry if I should ask over on the Digilent forums instead! I thought this might be an issue someone with SDK experience, and not necessarily Digilent board experience, might be able to help with).
The error is:
'xemacp' undeclared (first use in this function); did you mean 'xemac'?	arty_ethernet_000_bsp line 347 C/C++ Problem
I tracked it down to this line:
https://github.com/Xilinx/embeddedsw/blob/0c6cd096c8f81978854c782c7aa175241fc3af20/ThirdParty/sw_services/lwip202/src/contrib/ports/xilinx/netif/xadapter.c#L347
It's failing because neither 'XLWIP_CONFIG_INCLUDE_GEM' nor 'XLWIP_CONFIG_INCLUDE_AXI_ETHERNET' are defined a few lines above that.
Is there a config option I missed?
EDIT: I see that the example is using LWIP 141, while the latest vivado SDK pulls in LWIP 202. Could that be the problem? How would I use the older version instead?
Visitor edhalferty
Re: Arty LWIP example BSP failing to compile in SDK -
I was able to get this working by making changes to the xilinx lwip driver:
https://github.com/Xilinx/embeddedsw/pull/48
Observer davidfi1
Can you please add the workaround here?
