Visitor rd-ew
CFI query failed
I am using EDK 13.1 with a XC4VFX20 Custom Board.  I am trying to program an SREC file to the Linear BPI Flash using SDK at offset 0x8000.
I first programmed my software with the system.bit and .bmm files through the "Programming FPGA" tool in SDK.  Once that was successful, I attempted to program the Flash with the .srec file of my software project.  During this programming Flash step is when I get the error listed below:
ERROR: Flashwriter application reported an error: Unable to successfully query target part layout using CFI!
If anyone has any idea about how to get past this so that I can program the .srec to the Flash, or if there is a way to accomplish this same goal all through iMPACT, I would greatly appreciate it!  Thanks in advance!
Re: CFI query failed
This is posted in the wrong forum.  It should be in the Embeded Processor System Design to reach the right audience.
Scholar stephenm
You should check your emc memory controller layout to make sure that this is correct. You can use a bsb design as a reference ( I believe that the ml410 has a bpi flash). You can try impact to see if you can program here too. If your application is stored in internal BRAM and you use the download.bit file you mentioned above in impact, upon device config, your application will be executed.
You can also do a manual QRY by reading the relevant offset in your bpi via XMD
Open an ISE shell and launch XMD and use the command below:
mrd 0x<BPI flash="" address=""> 100</BPI>
