Observer sasisaketh
CPU_1x clock in Zynq APSoC
Please detail the relation between CPU_1x and the CPU frequency(50 - 667MHz) we set using clock configuration window of vivado for Zynq APSoC. I understand that CPU_1x, CPU_2x, CPU_3x and CPU_4x are relative with either 6:2:1 or 4:2:1 ratios. I need to understand this since I/O peripherals like SPI minimum clock is dependent on CPU_1x.
Saketh
Tags (2)
Re: CPU_1x clock in Zynq APSoC
Hi @sasisaketh,
From UG585(link)
The CPU clock corresponds to the clock CPU6x or CPU4x depending on your ratio (6:2:1 or 4:2:1):
The SPI could use the CPU_1x clock but also use a clock coming from another source. See example of configuation in the table 25-3:
Hope that helps,
Florent
Florent
Hi @sasisaketh,
From UG585(link)
Hope that helps,
Florent
Florent
