Does microblaze support uint64 or int64 data type
I have an application that uses 64bit variables. Does microblaze support 64bit variables?
Re: Does microblaze support uint64 or int64 data type
HI @vinit.apte,
MicroBlaze does not support the 64 bit variables.
the data types supported by micro blaze are:
Best Regards,
Srikanth
HI @vinit.apte,
Best Regards,
Srikanth
Scholar vanmierlo
Are you programming in C or assembler?
In C check if the compiler supports uint64_t for the microblaze when <stdint.h> is included.
In assembler you can create your own uint64 from two uint32's.
Thanks it is able to compile uint64 with stdint.h. I havent tried it on Silicon yet. I hope it works
