Visitor tiboy
FATAL_ERROR:Xst:Portability/export/Port_Main.h:127:1.17
I was creating a new ip cores on opb and the generate netlist was fail.
please help me ,thanks!
FATAL_ERROR:Xst:Portability/export/Port_Main.h:127:1.17 - This application has discovered an exceptional condition from which it cannot recover.  Process will terminate. For more information on this error, please consult the Answers Database or open a WebCase with this project attached at http://www.xilinx.com/support.
ERROR:MDT - Aborting XST flow execution...
INFO:MDT - Refer to D:\mp3\synthesis\mp3_decode_opb_0_wrapper_xst.srp for
   details
ERROR:MDT - platgen failed with errors!
Analyzing generic Entity <address_decoder> in library <opb_ipif_v2_00_h> (Architecture <IMP>).
 C_ARD_ADDR_RANGE_ARRAY = ("0000000000000000000000000000000011111111111111111111111111111111",
                           "0000000000000000000000000000000011111111111111111111111111111111")
 C_ARD_DWIDTH_ARRAY = (32,32,32,32,32,32,32,32)
 C_ARD_NUM_CE_ARRAY = (32,1,16,1,2,1,2,1)
 C_BUS_AWIDTH = 0
 C_USE_REG_OUTPUTS = true
WARNING:Xst:1994 - "d:/EDK/hw/XilinxProcessorIPLib/pcores/opb_ipif_v2_00_h/hdl/vhdl/address_decoder.vhd" line 145: Null range in type of signal <Address_In>.
WARNING:Xst:1995 - "d:/EDK/hw/XilinxProcessorIPLib/pcores/opb_ipif_v2_00_h/hdl/vhdl/address_decoder.vhd" line 354: Use of null array on signal <Address_In> is not supported.
WARNING:Xst:1994 - "d:/EDK/hw/XilinxProcessorIPLib/pcores/opb_ipif_v2_00_h/hdl/vhdl/address_decoder.vhd" line 101: Null range in type of signal <A>.
WARNING:Xst:1748 - "d:/EDK/hw/XilinxProcessorIPLib/pcores/proc_common_v1_00_b/hdl/vhdl/proc_common_pkg.vhd" line 243: VHDL Assertion Statement with non constant condition is ignored.
WARNING:Xst:1995 - "d:/EDK/hw/XilinxProcessorIPLib/pcores/opb_ipif_v2_00_h/hdl/vhdl/address_decoder.vhd" line 417: Use of null array on signal <Address_In> is not supported.
WARNING:Xst:1995 - "d:/EDK/hw/XilinxProcessorIPLib/pcores/opb_ipif_v2_00_h/hdl/vhdl/address_decoder.vhd" line 419: Use of null array on signal <Address_In> is not supported.
Re: FATAL_ERROR:Xst:Portability/export/Port_Main.h:127:1.17
Can you comment out the pcore that you created and see if synthesis is completed?
Can you let us know what is the OS and Memory of your PC ?
Do you see the same issue with all projects ?
BTW you can refer to XAPP967 to know how to use Custom peripherals.
Regards.
