HLS simple add function with axi stream Input/Output
Hi everyone,
i would like to build a simple IP-Core with the sum function and the IP Block shall have one AXIS Input and one AXIS output.
With following code I get it, but the thing is that Port B shall be an Output, but in Block design it is shown as input stream?
#include<stdio.h>
int sum(int num1, int num2, int A[50], int B[50]) {
#pragma HLS INTERFACE axis register both port=A
#pragma HLS INTERFACE axis register both port=B
    int num3;
    num3 = num1 + num2;
    return (num3);
  int i;
  for(i = 0; i < 50; i++){
    B[i] = A[i] + 5;
when I left the function with sum as follows, I get the input A and output B as this code is an example from Xilinx HLS:
void test(int A[50], int B[50]) {
  int i;
    B[i] = A[i] + 5;
So how can I manage it? Any ideas?
Thank you in advance
Tags (2)
Observer sreelaullas
Re: HLS simple add function with axi stream Input/Output
Check the following code.
#include<stdio.h>
#pragma HLS INTERFACE axis register port=A
#pragma HLS INTERFACE axis register port=B
int num3;
num3 = num1 + num2;
int i;
B[i] = A[i] + 5;
return (num3);
Sreela
#include<stdio.h>
int num3;
num3 = num1 + num2;
int i;
B[i] = A[i] + 5;
return (num3);
Sreela
@sreelaullas Hi, that worked for me. Thanks a lot!
