Observer abhishek7
How to design an soc on zc702 with both arm and microblaze
Hi how can i create an soc with both arm and microblaze in a single soc is can you please  help me with some example design.
regards
Abhishek
Re: How to design an soc on zc702 with both arm and microblaze
Yes, to access PS DDR you should use HP ports. Please refer to https://www.xilinx.com/support/documentation/application_notes/xapp1093-amp-bare-metal-microblaze.pdf for guidance
Hi @abhishek7,
Depending on what you are trying to do, it shouldn't be too complicated.
Do a design with a Microblaze on the zynq as if it was a FPGA.
If you don't use the DDR controller from the zynq (if you use BRAM for the MB), it should be straight forward. If you do, start first with BRAM
Observer abhishek7
hi @florentw i have done using with bram but large amount of data as to be stored so i have opted for ddr in zync(arm core) also i have custom ip which uses microblaze with streaming interface..
so how to be designed i have done soc and generated bitfile successfully but in sdk am unable to read,write in microblaze local memory and custom ip
thanks
regards
abhishek
Hi @abhishek7,
If you targeting the Microblaze, can you read into its local memory?
Observer abhishek7
no am unable to access the memory of microblaze..
Observer abhishek7
Hi @abhishek7,
Could you try in xsct, to do
mrd address_of_BRAM
Check for both targets (targets command). Make sure you can see the MB.
Observer abhishek7
hi @florentw in the present system i dont have bram in the design,currently am working with vivado2015.2 version and i have used targets command in xmd console it shows only arm cortex a9 but no microblaze the following file is attached below.can please help me out
thanks
regards
abhishek
Hi @abhishek7,
That could explain a lot. Make sure you are loading the correct bitstream.
Observer abhishek7
hi @florentw if we use ddr in system,should i enable  slave HP port??
Hi @abhishek7,
On the zynq yes.
But, as I said, you need to make the microblaze working without going through the DDR before.
Observer abhishek7
hi @florentw thank for the info by using bram its fine but now with ddr hwn i build a system the default address of ddr in zynq is 0x00100000 right,but when i enable HP port,in address editor it is set ddr address is set to 0x20000000  by auto address genrator.so what exactly is the infer for this?
Hi @abhishek7,
It depends on what you have in your system. However 0x20000000 is still in the address of the DDR for the AXI_HP port
Observer abhishek7
hi @florentw now everything works fine when do mrd,mwr to user ip,ddr,microblaze local memory is working fine but when i use putfsl functions in my code it does not work as i created application project with arm cotex not with microblaze and when i am trying to create application project with microblaze is gives error as this application project requires UART ip in the design but i have uart in arm enabled.can u please help me out.
Hi @abhishek7,
I guess this is because you are reading in the cache and you don't have the same value as in the DDR. You need to invalidated the cache (see here) or to use the ACP port
Observer abhishek7
hi @florentw this the code, where am not using data from cache...
Hi @abhishek7,
Sorry I misunderstood your previous post.
If you do not have an UART, then you cannot do printf...
