How to driver UHS-II SD card with FPGA
  Is it possible to drive UHS-II SD card with FPGA?
  If possible, and how?
  Is there any demo for it?
  I also search the forum before, and found some old posts, attached below
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/UHS-II-support-for-ZC706/m-p/489274/highlight/true#M33594
https://forums.xilinx.com/t5/Serial-Transceivers/GTP-SERDES-bidirectional-transfer/m-p/882547/highlight/true#M2118
Re: How to driver UHS-II SD card with FPGA
Hi @sxl630828191,
Zynq MPSoC is now supporting the SD with UHS mode. Please see below image:
you can find more about this in Zynq MPSoC TRM (UG1085) and at wiki page : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/498772/SD+controller
Best Regards,
Srikanth
Hi savula,
Zynq MPSoC only support SD UHS-I mode, not the UHS-II mode.
and what about drive SD UHS-II by PL side?
Best Regards
Hi @sxl630828191,
As of now we are only supporting SD in UHS-I mode only. PL side also not possible now.
Best Regards,
Srikanth
@savula
So, what's the point that we cannot use PL to drive UHS-II card?
Best Regards
