Visitor 145974
How to handle INOUT io signals in XPS and Microblaze?
I am using Spartan-3E starter kit. In XPS, we try to add a user module asyncethcat2.vhd (including submodule user_logic.vhd) to the Microblaze .
We first exported a template asyncethcat2, made changes to asyncethcat2.vhd and user_logic.vhd, and then inported the asyncethcat2 to XPS.
In asyncethcat2.vhd and user_logic.vhd, we have INOUT signal et1100_data, a 16 bit bus IO to the board expension connector. When in generate netlist, the XPS itself created a wrapper asyncethcat2_0_wrapper.VHD. The asyncethcat2_0_wrapper.VHD changed my original design from et1100_data to et1100_data_I, et1100_data_O and et1100_data_T. Then XST says mismatch:
Thank You!
ERROR:Xst:2585 - Port <et1100_data_I>; of instance <asyncethcat2_0&gt; does not exist in definition <asyncethcat2>. Please compare the definition of block <asyncethcat2> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <et1100_data_O>; of instance <asyncethcat2_0&gt; does not exist in definition <asyncethcat2>. Please compare the definition of block <asyncethcat2> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <et1100_data_T>; of instance <asyncethcat2_0&gt; does not exist in definition <asyncethcat2>. Please compare the definition of block <asyncethcat2> to its component declaration to detect the mismatch.
ERROR:MDT - Aborting XST flow execution!
INFO:MDT - Refer to
Since the wrapper is auto generated by the tool, I tried to hand correct the file, it did not help. When rerun "generate netlist&quot;, the wrapper is updated by the tool again.
Can you help solve the issue?
Mike
Re: How to handle INOUT io signals in XPS and Microblaze?
I think to create a MPD for a Bidirectional IO you can refer to GPIO MPD file and make sure that Input and Outputs are defined in a similar way.
And if i am not wrong, the file seems to be corrupted as the name of the wrapper is different <asyncethcat2_0&gt;>
You might want to cross check.
Hem.
