Voyager
Voyager
How to share memory between two microblazes?
I have a dual microblaze design. I would keep all the buses separated but i want the microblazes to communicate using a bram.
So every microblaze has its own LMB Bus with its own BRAM for data and instruction.
I tried to add a LMB BRAM controller with 2 LMB ports, 1 connected to LMB Bus of Microblaze 1 and the other connected to LMB Bus of Microblaze 2.
Then this controller have the BRAM port connected to Port A of a Dual Port BRAM (The other port is unconnected)
This solution doesn't work, i have problem when exporting design to SDK in the bram initialization i suppose...
How is the correct way to do this?
Teacher muzaffer
Re: How to share memory between two microblazes?
make an axi interconnect with a 2x1 crossbar and attach the two slave ports to each mb and the master port to the blockram controller.
Voyager
Voyager
Thank you for your suggestion, i used the already present axi lite buses, 1 for each microblaze and then i connected 1 controller for each bus.
Maybe your solution is better, i will try
