I2C Slave driver flags XIICPS_EVENT_ERROR for error-free receive
  Setup:
    Tool: SDK 2016.3
    IP core: Zynq PS I2C
    Driver version: iicps_v3_0
    Zynq I2C is slave and needs to receive variable length I2C write commands from master.  I am using 1 addr + 2 data byte write for testing.  I have checked on Vivado ILA Zynq I2C acknowledges each byte transfer correctly.  An interrupt is generated after master generate I2C stop condition.
    I am running I2C Slave example which init rx buffer to 250 bytes.
  In the ISR,  event XIICPS_EVENT_ERROR  is generated by ISR.
xiicps_slave.c, line 521:
  if (0U != (IntrStatusReg & XIICPS_IXR_COMP_MASK)) {
    if (IsSend != 0x0U) {
      if (InstancePtr->SendByteCount > 0) {
        StatusEvent |= XIICPS_EVENT_ERROR;
      }else {
        StatusEvent |= XIICPS_EVENT_COMPLETE_SEND;
    } else {
      LeftOver = SlaveRecvData(InstancePtr);  <------  returns 248.  Buffer is 250 bytes, filled up with 2 bytes, so leftover 248
      if (LeftOver > 0) {
        StatusEvent |= XIICPS_EVENT_ERROR;  <------ XIICPS_EVENT_ERROR  generated here
      } else {
        StatusEvent |= XIICPS_EVENT_COMPLETE_RECV;
  Why does driver flags a error event when data is correctly received?  I intend to create my own version of ISR to flag XIICPS_EVENT_COMPLETE_RECV instead.  Anyone know whether this will create any potential problem down the road?
Neo
Re: I2C Slave driver flags XIICPS_EVENT_ERROR for error-free receive
Hey Neo,
Because it assumes that a proper I2C receive has to have 250 bytes (from the rx buffer size).
This is fine, just keep in mind that you change the semantics.
As long as you know how many bytes have been received, it should be fine.
Best,
Herbert
Tks Herbert.
  I was expecting the API to provide I2C slave functions just like most other I2C ICs that accept variable length writes.
Neo
