ISIM updating
I simulate a microblaze project with ISIM, but every time i change the c code i should delete the testbench.exe file and rerun simultaion to get the ISIM result updated, how can i avoid doing this?
Re: ISIM updating
I looked at the XPS console to see how the exe is generated and here is an example
Running: C:\Xilinx\14.4\ISE_DS\ISE\bin\nt64\unwrapped\fuse.exe -incremental work.system_tb work.glbl -prj system.prj -L xilinxcorelib_ver -L secureip -L unisims_ver -L unimacro_ver -o isim_system.exe
As we can see the incremental switch is already enabled which means that it Compiles only the files that have changed since last compile.
So IMO even though there is a change in the C code, you might want to regenerate the complete exe again.
But a quick suggestion would be to use Re-launch option in ISIM GUI
--Hem
