Visitor vineeshvs
Is it necessary to have a processing system (Microblaze in my case) in a design?
We have a custom processor design and we plan to build a system with UART, PCI, Ethernet etc. Is it necessary to use Microblaze processor or any PS IP from Xilinx to do this?
Re: Is it necessary to have a processing system (Microblaze in my case) in a design?
@vineeshvs
A bare metal solution (all PL) is fine if you have a clock to drive.
Visitor vineeshvs
Okay. Any tutorials/ example projects?
Hi @vineeshvs,
There is an example project available in Vivado with Open risc CPU, you can take reference from there. In order the add UART controller and Ethernet block, you can refer to microblaze example project.
You can also refer to some open source CPU projects available on internet. If I remember correctly Princeton university has developed a similar design with their opensource processor named Openpiton with Xilinx FPGA. You can take reference from there, they have good amount of documentation available for that. Hope this helps.
Chinmay
Here's an example Verilog project that uses the ZipCPU on an Arty board.  You'll find a lot of documentation about the components of this design on the ZipCPU blog.
Dan
Hi @vineeshvs,
It is not necessary to use Microbalze or PS processor. You can use you customer processor design with peripherals as well.
Not sure what issues are you encountering by doing such step.
Praveen
