Visitor chmousset
JTAG and mode pins
I'm having troubles running the FSBL from JTAG when the mode_pins are set to QSPI boot.
JTAG download does work, and running the FSBL doesn't trow any errors but I can't see any FSBL output on the serial terminal.
If I change the mode_pins to JTAG boot everything works like a charm as I can see the FSBL output on the serial terminal.
Is there a way to make debug work regardless of the mode_pins settings?
Scholar pratham
Re: JTAG and mode pins
@chmousset Give this a try.
For MPSOC,
Add the following change to in FSBL(xfsbl_initilization.c) and give it a try.
                * Read Boot Mode register and update the value
                BootMode = XFsbl_In32(CRL_APB_BOOT_MODE_USER) &
                                                CRL_APB_BOOT_MODE_USER_BOOT_MODE_MASK;
                //Add this line
                BootMode = XFSBL_JTAG_BOOT_MODE;
A similar line can be added for Zynq in main.c
-Pratham
Scholar pratham
For MPSOC,
                //Add this line
-Pratham
Visitor chmousset
@pratham thanks, I tried this solution and works but it's a bit tricky to use.
basically, I need two different FSBLs, one for production (flashed on the QSPI) and another I load through JTAG, with the actual modification.
It works most of the time, but I couldn't get it to be 100% reliable.
Visitor chmousset
@stephenm well that's exactly what I was hoping for!
I'll give it a try later.
thanks
Visitor chmousset
Turns out there seems to be no alt_mode options for Zynq-7000, only for utltrascale.
I'll go the way @pratham advises.
