Low Speed I/O muxing between EMIO and PL, any pitfall?
We have existing SD controller in HDL, we'd like to try to use PS to drive it.
Although PS has dedicated pins for SD, but we'd like to start with our existing controller, later on maybe move to PS.
Can we realize this by having PS/SD enabled to EMIO and have a MUX inside PL to choose which controller to use.
Please comment,
Re: Low Speed I/O muxing between EMIO and PL, any pitfall?
Correct. I am not an SD expert, but that's what I'd suggest. You will not be able to use SD as a 1st boot device via EMIO, obviously.
Perhaps if you used PL I/O you could use SD EMIO for the PS controller and custom PL.
It is not possible to access the dedicated MIO pins with PL logic.
Thanks for the reply, I think you mean EMIO and PL muxing will work.
Absolutely, I understand PL comes after PS boot.
