Visitor igortf
MicroBlaze KC705 2GB
I have some doubts about the Microblaze Cache configuration. I want to use a 2GB memory with a MIG 7 Series memory part MT8KTF25664HZ-1G6. But, the UG940 document talks that I need have space from Instruction and Data Cache in the range. And the difference between the high and base address must be a power of 2. Considering the attach picture, how can I configure the addres (red rectangle) to keep (and work) the 2Gb set in MIG (green rectangle)?
Thanks in advance,
Igor
Voyager
Voyager
Re: MicroBlaze KC705 2GB
@igortf: You can only have 2-GB of addressable memory.  The only other, larger option is 4 GB, and that would take up the entire addressable space--which is not practical.  There's nothing stopping you from using a memory that's larger than 2 GB, but you can only access 2 GB of it; the memory above (or below*) the addressable 2GB is unreachable.
You must place an addressed block at an address that is a multiple of its size.  0x4000_0000 is a multiple of 1GB, not of 2 GB.  In a 32-bit address space, you can only place a 2-GB block at 0x0000_0000 or at 0x8000_0000.  See the referenced link above--they placed their memory at the latter address.
-Joe G.
* Depends on how you strap the unused, high-address bit(s).
Voyager
Voyager
Igor,
Not to pick a nit, but the rule is "the size of the cacheable segment of memory...[must be] a power of 2", not "the difference between the high and base address must be a power of 2".  The 'difference' between address location 0 and address location 1 is 1, but the size of address range [0:1] is 2 locations.
That said, the size of the segment between 0x8000_0000 and 0xFFFF_FFFF is 2 GB, which IS a power of 2 (2^31).
Also see: KC705-DDR-size-extention
-Joe G.
Visitor igortf
@jg_bds But when I try set the base address to 0x4000_0000 and the high to 0xFFFF_FFFF (3Gb), I get an error. So, I can't put my 2Gb memory and 1Gb more, for cache, inside the cacheable segment.
Thank you for support,
Igor
Voyager
Voyager
-Joe G.
Visitor igortf
@jg_bds
Thank you. This help me a lot.
Igor
