Visitor begleysm
Microblaze as a component in a non-ISE, XST workflow, EDK 10.1, design
Hello everyone,
I am trying to put a microblaze in a system that does not use ISE.  This system is built on a Wildstar4 board by Annapolis Microsystems.  It's a big honker with 4 Virtex4 FPGAs on it.  AMS (Annapolis Micro Systems) has come up with a whole VHDL board support package so ISE is out of the question.  The build workflow that I am using is XST from the command line.
So far, I've used EDK to create a microblaze and use "Hardware" -> "Generate Netlist" to create all the NGC files.
I've instantiated the microblaze into my FPGA design and attempted to build the project.  I get a a couple errors (multiplied many times because I am using 2 32-bit GPIOs).  These errors appear to be related to IO-Buffers.  I believe the Microblaze is assuming it will be talking to external parts.  Therefore it is assuming it has to create IOBUFs when it probably shouldn't.
I am told that older versions of EDK had an option under "Project" -> "Project Options" -> "Hierarchy and Flow" that allowed to you specify that your microblaze would be used as a component and not as a top level.  How can I achieve using the 10.1 tools?
I've attached the .bld showing the errors and my .vhd that instantiates the microblaze.
Sean
Tags (4)
Visitor begleysm
Re: Microblaze as a component in a non-ISE, XST workflow, EDK 10.1, design
I have managed to solve this problem with some help from the Xilinx WebCase Support Team.
Here is a link to a post where I detail how to put a Microblaze into a command line workflow project.
http://forums.xilinx.com/t5/EDK-and-Platform-Studio/HOWTO-How-to-use-an-EDK-Microblaze-with-a-non-ISE-command-line/m-p/70994
Hope someone can use this!
Sean
Hi Sean,
Try to open your xmp file and modify the line:
InsertNoPads: 0
to
InsertNoPads: 1
to generate the microblaze system with no io pads.
Visitor begleysm
Sean
