Visitor kaushal
Microblaze boot loop in bitstream
I am trying to use Microblaze core without any local memory support on ZC706. That is, core is configured with I/D cache and the I/D cache interfaces are connected via HP ports to DDR. Microblaze is configure to run from address 0x30000000 on reset.
In-spite of not having any local memory (BRAM), vivado is including mb_bootloop_le.elf in bitstream as per bitstream log.
Successfully populated the BRAM INIT strings from the following elf files :path-to-mb_bootloop_le.elf
So, where will mb_bootloop_le.elf be loaded? Is there a way to remove the initialization. I am using Vivado 2014.2.
Kaushal
