PS can't access ZYNQ PL
Hello everyone,
     I am a beginner with ZYNQ, trying to create a system (ZC702 Kit) with both PL and PS.
     The problem that I am facing is that I cannot access the mapped IP cores addresses (from XMD, nor from the bootloader source code with read/write commands) even though I have enabled the level shifters and axi interfaces before accessing the corresponding locations (FsblHookAfterBitstreamDload in fsbl_hooks.c).
      I only have a bootloader, a .bit file and an application, and the error I get is:
Error while handling inferior event:
Remote failure reply: E01
      Does anyone have any idea about the cause and/or solution of this problem?
Thank you very much,
Elena
Re: PS can't access ZYNQ PL
ZYnq supports a PS power-on only mode but does not support a PL only mode. User software in the PS can turn the PL fabric power on/off at any point of time, which reduces the static power required. When the PS is powered  off, it holds the PL in a permanent reset condition until the PS comes out of reset.
Thanks and Regards
Balkrishan
Could you share files to test?
Praveen
