Voyager
Voyager
Peripheral with Synplify Pro ...
I have to integrate a peripheral in EDK system. This peripheral must be synthesized with Symplify Pro and not with XST . I have organized the peripheral in this way:
Peripheral
\----- data
| \----- peripheral_v2_1_0.bbd
| \----- peripheral_v2_1_0.mpd
| \----- peripheral_v2_1_0.pao
\----- hdl
| \----- vhdl
| \----- No File
\----- netlist
\----- peripheral.edn (Generate with Symplify Pro)
\----- fifo_2kx8.ngc
Files
peripheral.edn, fifo_2kx8.ngc
BEGIN peripheral
## Peripheral Options
OPTION IPTYPE = PERIPHERAL
OPTION IMP_NETLIST = FALSE
OPTION HDL = VHDL
OPTION IP_GROUP = MICROBLAZE:PPC:USER
OPTION STYLE = MIX
OPTION RUN_NGCBUILD = TRUE
## Bus Interfaces
## Generics for VHDL or Parameters for Verilog
## Ports
END
File is empty.
I then imported pcore on EDK project and made all the necessary connections without error. I start the generation of bitstream but there are always errors that do not understand.
Anyone knows the exact procedure to import a pcore presynthetized with Symplify ?
Thanks very much.
secureasm
Re: Peripheral with Synplify Pro ...
Is the error info related to the IO Buffer or IOBs?
