Participant msauerpb
Problem with interrupt definition on Concat Pins
I have extended our existing Artix 7 design (block design with 2 micro blaze cores) with a new module which produces an interrupt. I expanded our concat module (which concatenates the 3 other interrupt signals) and connected my new interrupt signal.
On the 3 other signals I can change the port type and the sensitivity but on the new signal I can't it.
old.pngExisting Int Signalnew.pngNew Int Signal
Can you tell me, how I can define the new pin as interrupt?
Thank you for your help.
BR
Martin Sauer
Re: Problem with interrupt definition on Concat Pins
Hi @msauerpb ,
The query is not completely understandable, could you please provide more information?
Is your IP customized? Could you paste the Design snapshot ?
You mentioned new module is it configured with interrupt enabled?
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
[Solved] Re: Problem with interrupt definition on Concat Pins
I found the solution. I have to define the signal (IntHVM) as interrupt in the package editor:
BR
martin
