Visitor workingonit
Purpose of using Zynq7 processing system
Deal Xilinx fans,
What does the zynq7 processing system do when we integrate it to our BD, what is the purpose of it? I already read the doc but it's not clear to me. If my understanding is correct, the ZYNQ7 processing system connects the PL and PS part of the zynq7000 SoC, but this means that we always use the Zynq processing system 7 we deal with Zynq SoCs? which is not true.
Visitor dror
Re: Purpose of using Zynq7 processing system
the only reason to use Zynq is because of it Processing System (ARM).
if you are not using it then u have bought a very expensive FPGA with no reason. the ARM is very expensive and it is taking a large amount of the FPGA area.
when you integrate it to the BD then it is like any other IP, you use it. that mean that you have a processor in the FPGA and you can use all the abilities and peripheral like the PS DDR, USB ext.
as it was mentioned by u4223374, this is the PS, and when u use it in the BD all the connection that you see is from the PS to the PL (Programmable Logic = FPGA).
Scholar dpaul24
@workingonit,
The short anaswer is that you have a pre-verified embedded processor core which is able to perform tasks specified using C code.
FPGA enthusiast!
All PMs will be ignored
Hi @workingonit
In your BD, the Zynq Processing System represents your PS part. Even if you do not add it to your BD, it will be present on the device as this is a hard IP.
The reasons why you would add it to the BD:
  • This is the way you can configure it. This configuration will be then transmitted to SDK through the HDF file.
  • This represent your interface to the PL
You do not need to use it in your BD as you wouldn't need to use it. But in most cases you will use it, because you can get the clocks from it.
Hope that clarifies
Scholar u4223374
@workingonit wrote:
Deal Xilinx fans,
The ZYNQ7 Processing System is the PS. That's what PS stands for.
As far as I know, it's not possible to use the Zynq without some minimum level of involvement by the PS, as the PS loads the PL during the intial boot stages.
Scholar dpaul24
@workingonit,
I have a Zybo Z7-10 dev board and as a start project I wrote down some VHDL to blink on-baord LEDs. No PS involved, only PL.
Then later I did a HDMI pass through project, using only IP cores from Digilent and a top level VHDL wrapper, which again involves only the PL.
Conclusion - As far as I know, you can use the PL independently of the PS.
FPGA enthusiast!
Visitor dror
