Questions on CPU and FPGA communication through Linux drivers
Dear Xilinx Support community and all users,
I am working with Microzed board, I can successfully run a Linux distribution and I would like to communicate with the inner FPGA.
My main interest is to write data into some custom register implemented through VHDL design (or simply toggle a GPIO ..), from a user space application. I am pretty sure it can be done with some device drivers.
If possible, I would like to not use the SDK.
I mean, having the kernel source code, I would like to develope my own driver using the additional xilinx development files (for macro, structure declarations etc.) , compile the driver and use it in my own distribution, as I always did with common drivers testing.
I also think I should include another IP block in addition to the Zynq Processing System in Vivado.
Could you please provide detailed information on this specific topic ?
Thank you in advance,
Best regards,
Simon
Teacher muzaffer
Re: Questions on CPU and FPGA communication through Linux drivers
@simozz no need for a kernel driver. If all you want to do is to toggle a gpio, just mmap the physical address of the IP (axi-gpio?) and write to the virtual address you get as a result to access the registers of the IP.
Hello @muzaffer, thank you for your suggestion.
I mentioned the example of toggling a GPIO just as a basic one.
Today I will reading the documentation of the AXI interface.
My question arise from the UG873 zio file which can be downloaded here.
Driver code for toggling a GPIO can be found into the zip file.
I could compile that code without sdk, just with arm xilinx gcc from shell, and execute into my Zynq board. The code doesn't work, however this is not big a problem.
Regards.
Simon
