Observer aroytman
Reading eeprom over i2c mux
I am searching for a way to read/write an eeprom that is connected to i2c via a mux. This has to be done via command line at u-boot prompt.
I am using (a board similar to) zcu102. So, a procedure that will work on that board is OK.
Per ug1182, on zcu102 there is an eeprom connected to channel 0 of pca9548a mux at i2c address 0x54.
The mux is connected to i2c_1 at address 0x74.
I do not know how to reach the eeprom. I tried many ways, none worked.
I am not using the DM drivers.
Thank you very much
Re: Reading eeprom over i2c mux
Hi @aroytman ,
There is an example for eeprom access over I2C through mux.
Please refer to this source file - https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/iic/examples/xiic_eeprom_example.c
Praveen
Observer aroytman
Thank you very much for the pointer.
Actually, I was looking for a way to do this via command line at u-boot prompt.
Hopefully, I will not have to reverse engineer this code and translate it to i2c commands.
Anyway, as last resort, this code is good hint.
Thank you
Hi @aroytman ,
Here is commands to be used in Uboot.
Writes different patterns to the I2C EEPROM, reads back the contents of the EEPROM and performs data verification.
ZynqMP> i2c bus
Bus 0: i2c@ff020000
ZynqMP> i2c dev 0
Setting bus to 0
ZynqMP> i2c speed
Current bus speed=400000
ZynqMP> i2c probe
Valid chip addresses: 00 0A 0B 0D 0E 0F 10 11 12 13 14 15 16 17 18 1A 1B 1C 1D 1E 20 50 68 70 71 72 73 74 75 76
ZynqMP> md.b 100000
ZynqMP> mw.b 100000 cc 10
ZynqMP> md.b 100000
ZynqMP> md.b 200000
ZynqMP> i2c write 100000 50 0.1 10
ZynqMP> i2c read 50 0.1 10 200000
ZynqMP> md.b 200000
Praveen
