Observer alextennant
Secure boot Software Reset
Hi All
Is it posible in any way to allow a system reset when booted in secure boot mode?
Our setup on Zynq 7020
1) eFuse AES key set
2) eFuse AES only set
3) encrypted FSBL in QSPI flash
4) Fully encrypted boot.bin including linux ramdisk loaded
We need a method to reboot the system from linux once running, any attempt made results in a secure lockdown.
What I would like to happen is basicaly a software triggered Power On Reset.
Is this posible from within the Zynq?
I haven't managed to find anything in the Technical Reference Manual
Alex
Re: Secure boot Software Reset
To trigger fallback or multibot in secure boot mode with EFUSE, you have to comment out the system reset section in FSBL.
Please refer to "Secure Fallback Flow with eFUSE" section of http://www.xilinx.com/support/documentation/user_guides/ug821-zynq-7000-swdev.pdf for details on how to do this.
Do you want to reset some sections of PS or the whole system?
PS_SRST_B or SOFT_RST resets the whole system but the boot mode pins are not sampled after this.
I need a way to resets the whole system but PS_SRST_B and SOFT_RST result in a secure lockdown when using secure boot.
Is this the intended functionality when using secure boot?
Yes, as mentioned above the mode pins won't be sampled after PS_SRST_B/SOFT_RST.
Hi Smarell
Could you please be clearer
You have said nothing about secure boot and lockdown.
Should I be able to use PS_SRST_B/SOFT_RST from a secure boot without going into lockdown?
Alex
I want to re-trigger the FSBL on a Zynq7020 after booting into a secure image using only software. Writing a 1 to register (PSS_RST_CTRL) results in a secure lockdown.
My FSBL is:
the_ROM_image:
  [aeskeyfile] aes.nky
  [encryption=aes, bootloader]FSBL.elf
using the efuse AES key
After booting the FSBL shows this:
"User not allowed to do any system resets"
This is from Xilinx's default FSBL
Now once I have fully booted into linux, I want to reboot the device all the testing I have done results in secure lockdown. Now this may be the intended operation for a secure boot and it is imposible to do what I want without externaly triggering a Power On Reset.
If anyone knows if this is possible please let me know.
Hi Smarell
I have multiboot and fallback working on my secure boot.
As I understand it your suggestion is to basicaly handoff back to the FSBL (still in the on chip memory) from Linux?
Alex
Yes, thats correct.
Observer jqsam1
Hi... i need a similar functionality... executing the FSBL after fallback but not on a secure boot scenario.. any idea how i can do this?
