Visitor nkumar3119
Share DDR memory region between 2 ARM cores in Bare-Metal
I have followed XAPP1079 example and it works. I'd like to know how to share DDR memory region between 2 ARM cores in bare-metal application. My data structures are huge and can not be used in OCM. Also, please show how this affects lscript.ld for both applications since each lscript.ld makes a region of memory visible to each core. I would like to modify xapp1079 to achieve this.
Thank you.
Teacher muzaffer
Re: Share DDR memory region between 2 ARM cores in Bare-Metal
Just map the same address to both processors. So instead of exclusive DDR addresses, map the same region on both processors. Of course after you do this managing the ownership of the data structures in DDR is something to be done explicitly, ie locks, mutexes etc.
Visitor nkumar3119
How is the common region map on both processors? Would you have any examples? Is it via lscript.ld?
Sorry still new to this.
Visitor gerald1010
can you provide your configuration file or can you upload the project? which zynq do you use?
G
