Visitor maio
Unable to instantiate 2 Microblaze processors due to BSCAN2 being place in the same location for both
I'm trying to provide as much information as possible.
I'm using Vivado 2017.3, the part I'm applying my design to is xcvu9p-flgb2104-2L-e.
I have designed using IP Integrater a microblaze system that includes the mdm submodule. I used vivado to generate a wrapper then added all the files with corresponding XCI files to a filelist script and added them to the bigger project where the microblaze is supposed to go. Instantiating one microblaze works fine.
However when trying to instantiate the second one, it looks like it is trying to use the same BSCAN2 BEL. This is the first error I was getting:
ERROR: [Place 30-1100] Failed to do pre-placement. Reason: Cannot place instance microblaze_1/[...]/Use_E2.BSCAN_I/Use_E2.BSCANE2_I of type BSCANE2 in site CONFIG_SITE_X0Y1 with message Instance microblaze_1/[...]/Use_E2.BSCAN_I/Use_E2.BSCANE2_I can not be placed in BSCAN2 of site CONFIG_SITE_X0Y1 because the bel is occupied by microblaze_2/[...]/Use_E2.BSCAN_I/Use_E2.BSCANE2_I(port:). This could be caused by bel constraint conflict
I went through the placing constrains that are set for the project and couldn't find anywhere something that was constraining both microblazes in the same area. I then noticed there are only 3 BSCAN2 BELs in the whole device:
get_bels *BSCAN2*
get_bels: Time (s): cpu = 00:00:08 ; elapsed = 00:00:09 . Memory (MB): peak = 10073.879 ; gain = 0.000
CONFIG_SITE_X0Y2/BSCAN2 CONFIG_SITE_X0Y1/BSCAN2 CONFIG_SITE_X0Y0/BSCAN2
I attempted to constrain each microblaze to another SLR. Now I'm running into this:
ERROR: [Place 30-1100] Failed to do pre-placement. Reason: Cannot place instance microblaze_2/[...]/Use_E2.BSCAN_I/Use_E2.BSCANE2_I of type BSCANE2 in site CONFIG_SITE_X0Y1 with message microblaze_2/[...]/Use_E2.BSCAN_I/Use_E2.BSCANE2_I placed on site CONFIG_SITE_X0Y1 rpm (3552, 749) tile (583, 558) CFG_CONFIG_X100Y360 is outside its area constraints. The BSCANE2 can be only instantiated in the master SLR in SSI devices.
Can I only instantiate it in the "master" SLR? Can I use a different BSCAN instance for each microblaze instance? Do you know any other way I could tackle the issue I am facing?
Re: Unable to instantiate 2 Microblaze processors due to BSCAN2 being place in the same location for both
I would suggest removing the MDM IP block in your current MicroBlaze subsystem Block Diagram and instantiate that in your upper level HDL.  The MDM has the option to configure for multiple MicroBlaze processors.  You would set this to the number of MicroBlaze subsystems you are instantiating.  In your case, I believe this is '2'.
You will go from a MicroBlaze Subsystem as follows (including MDM):
To a MicroBlaze Subsystem as follows (excluding MDM) which will add external ports for the DEBUG and MicroBlaze Debug Reset:
That should get you over your place error.
Thank you.
Thank you.
You can Configure the MDM to specify the BSCAN location.
https://www.xilinx.com/support/documentation/ip_documentation/mdm/v3_2/pg115-mdm.pdf#page34
Also, With multiple mdm you would need to tell the debugger to scan all bscan otherwise the won’t be detected:
https://www.xilinx.com/support/answers/64003.html
However, as Mike said you should just instanciate a single MDM with multiple debug ports. You are wasting resources that you might need for hw debug such as the ILA.
Visitor maio
Thank you for your suggestions.
For the final solution, I removed the MDM from the IP Block design, generated another block design in the same project that only had the MDM and then manually modified the top-level wrapper to instantiate the MDM based on a generic. This way I can have the debugger enabled with one FPGA build and I don't mess with the top-level interface of the Microblaze.
