Using and debugging two PowerPC core in a Virtex5 FXT 100
I am using Virtex5 FXT 100, and I would use the two independents PowerPC cores inside. Is there any reference design or sample using two cores in the same project of EDK? Can I debug at the same time two cores?
begos
Re: Using and debugging two PowerPC core in a Virtex5 FXT 100
Please refer http://www.xilinx.com/support/documentation/application_notes/xapp996.pdf
Thnx
