Voyager
Voyager
Using of the AXI Quad SPI v3.2 LogiCORE IP
In the Vivado example, generated for the AXI Quad SPI v3.2 (configured as Master) there is no ouput clock (sck_o port).
Is it normal ?
Re: Using of the AXI Quad SPI v3.2 LogiCORE IP
Hi @pavel_47,
It is expected behavior only. when ever the startup primitive enabled in the core then the sck signal is part of the core and not visible as output port. below is the figure when startup primitive is enabled.
If I disable the Startup primitive like below
then it will shows the sck signal as below:
Please refer axi quad spi for more details.
Best Regards,
Srikanth
Hi @pavel_47,
Best Regards,
Srikanth
Voyager
Voyager
Great !
