Observer cuenca
Vivado 2013.3 Zynq ip customize window doesn´t appear
Hi all,
I´ve created a new design an added a "zynq7 processing system" ip.  Then select the zynq ip and click on Customize ip icon. A window with the message "Re-customized ip" appers for a moment, but any other window appears to configure the zynq system.
My computer, i5 windows7 (64b).
Need some help.
TIA
Observer cuenca
Re: Vivado 2013.3 Zynq ip customize window doesn´t appear
the problem seems to be related to the corruption of the installation tar file.
I have download the tar file again and now it works fine.
It is a good idea to verify the md5 checksum.
Are you not directed to dialog box as shown below after clicking on customize IP/double clicking on the IP? Are there any errors/warnings in the console?
Is this a new project in 2013.3 or migrated project from older versions?
Deepika.
Deepika.
Observer cuenca
no the dialog box doesn´t appear, and no errors/warning in the console.
It is a new design
Is there a possibility to try this on a different machine?
--HS
Can you try creating new project and check if you face the same problem?
Did you check md5 checksum of download before installing vivado?
Deepika.
Deepika.
Observer cuenca
