Visitor doketo
Vivado 2017.2 merge Bitstream and Elf files
Hello friends, i have a problem with merge of bitstream and elf file on Vivado 2017.2. I use standard methodology with associate elf file in MicroBlaze block. In end result my application won't load in BRAM. Please help for solution! :-)
Re: Vivado 2017.2 merge Bitstream and Elf files
Hi @doketo
Open your project in SDK--> Click on Program FPGA --> Then it will ask for the elf file path, give the path and click ok,
go to your project.sdk folder and search for download.bit file.
This is the only way i know and using it. Hope it works.
Madhu
Hi @doketo
Madhu
Visitor doketo
Thank you Madhu, it work! :-)
hi
My vivado is also 2017.2,but my device is spartan7-50-fgg484.
Vivado cannot generate download.bit.
Help!!
Michael
Thanks for god,I meet FPGA.
