Visitor serdarrpf
Wirte and Read bit pattern into a fast memory
I am beginning to learn about the ZedBoard. I am a complete beginner, so that's why I have a hard time with the ZedBoard.
First I want to write some bits into a memory (I guess DDR3?) and the read it and transfer it to FMC Pins.
Is there any tutorial in how to do this. What should I look at? I have no idea how to start my journey with the ZedBoad. IThe Board is really complex.
Thank you for your help.
I am using Vivado 2014.4 on Windows 7
Re: Wirte and Read bit pattern into a fast memory
You can start wuth Getting Started Guide
http://zedboard.org/sites/default/files/GS-AES-Z7EV-7Z020-G-14.1-V2.pdf
More links, you can select the design that meets your requiremnt.
http://zedboard.org/content/write-data-ddr3-through-pl
http://zedboard.org/content/how-communicate-ddr3-ps-zedboard
http://zedboard.org/design/1521/11
Hope this helps
-Vanitha
