Observer sulemanzp
Write data to Zynq DDR from PC's PCIe
Hi all. I am trying to send date from PC to the DDR memory connected with Zynq. Currently, I am using AXI Memory mapped PCIe IP to connect my zynq (PS + PL) based design with Windows PC. I am sending data from PC to PL Fifo by using AXI 4 Custom IP and then reading that FIFO by using PS Master AXI port and send that data back to PC via ethernet.
Now I want to send a large data of about 50MB which I can not store in FIFO. So I want to store that incoming data from PCIe IP to DDR attached with PS.
I do not know how can I achieve this. Can I directly connect the AXI Memory Mapped PCIe Master port with 32bit GP Slave Port of Zynq IP?. (in between data comes in 32 bit format from PCIe). Or I must have to use one of the below mentioned DMAs or there is any simpler way of doing this.
(1) AXI Central DMA
(3) AXI DMA Engine
Note: I Never used DMA before;
Specs:
Vivado 2014.2.
Windows 7
PicoZed 7030 + Carrier Card Board.
Tags (4)
Re: Write data to Zynq DDR from PC's PCIe
Hey @sulemanzp,
I'm not sure I completely understand your current setup (it sounds a little bit over-complicated to me), but here is what I think I got:
  • You have a ZYNQ based PCIe card which is plugged into a Windows PC.
  • The data sent from the Windows PC goes to a FIFO and then to the AXI bus.
  • The PCIe endpoint is somehow memory mapped and can be accessed from the PS via one of the general purpose master ports.
  • Some application on the PS processes the data and sends back replies via ethernet
The problem now is that you want to send more data than the FIFO can hold, so the question is:
Can the data received via PCIe somehow be transferred into DDR memory for further processing?
If I am right so far, here is my answer:
Yes you can do that by utilizing one of the PL slave ports (either of the high performance, general purpose or acp) and sending the data directly into DDR memory where it can be accessed and processed from the PS application.
Hope this clarifies,
Herbert
Scholar hbucher
@sulemanzp  You should have a look at the DMA/Bridge Subsystem for PCI Express v3.0
https://www.xilinx.com/support/documentation/ip_documentation/xdma/v3_0/pg195-pcie-dma.pdf
Observer sulemanzp
Please correct me if I am wrong. DMA for PCI Express (PCIe) Subsystem IP does not support Zynq and I also don't think it's available in Vivado 2014.2. As I am restricted to this version because of remaining code in the project.
Scholar hbucher
@sulemanzp
I do run the DMA/Brigdge on my ZC706 board, which is Zynq 7000.
But you are right, on 2014.2 it seems you have to stick with the 7 series integrated block.
https://www.xilinx.com/support/answers/61087.html
But if you can, please upgrade to latest as the DMA/Bridge already incorporates all the pieces you need.
Hey @sulemanzp,
Herbert
Observer sulemanzp
Hi @hpoetzl,
let me clear the FIFO part. PC write to FIFO via PCIE interface and PS read data from that FIFO and process.
PCIe_M_AXI -> S00_AXI_MY_CUSTOM_IP -> WR_DATA_FIFO
PS_M_AXI_GP0 -> S01_AXI_MY_CUSTOM_IP -> RD_DATA_FIFO
Ok. I followed your guide and created a block design. Below is the picture please let me know if I am doing right.
Now PC will write on 0x00000000 to 0x03FFFFFF offset, the data will route to DDR in PL and once data is transferred. PS will read from the same offsets of DDR. Right? If Yes. I will build the project and test.
