Newbie royi
Xilinx MicroBlaze Floating Point Compatibility
I have a 'c' code targeted to a MicroBlaze CPU.
When I debug the code as c program in Eclipse + GCC or Visual Studio I get the results I want.
Yet when I run on the target the result are different.
It happens only on floating point operations (Multiplication and Division).
How can I make it work with full floating point precision?
Are there special GCC flags?
Re: Xilinx MicroBlaze Floating Point Compatibility
SDK should be able to set the compiler settings automatically.
However i remember there is a stack requirement as mentioned here. http://www.xilinx.com/support/answers/29787.html
Refer to the snapshot as attached here
--Hem
MicroBlaze is doing a subset of IEEE754 (denormalized numbers are consider to be zero).
What is the difference that you see?
Göran
