Xilinx SDK error
Accepted Solution Solved
Accepted Solution
Xilinx SDK error
I am a beginner in SDK and build a microblaze by my vertix5 board.The development environment is ISE14.6 and XPS P6.8
Everything like "PROGRAM FPGA" has been done until I want to run my program .
click the buttom then SDK told me:Launch Failed:Binary not found.
why should this problem occured?
how to resolve this proble?
Kudos: 106
Solutions: 105
Re: Xilinx SDK error
[ Edited ]
This error message occurs when the SDK can't find the binary file to run on the board. This is easily solved by explicitly specifying a run configuration. Instead of selecting Run As->Run on Hardware, choose Run As->Run.  From the Run... window, the run configuration that points to the proper .elf file can be selected. Remember the run configuration must match the build configuration
Harry
All Replies
Kudos: 106
Solutions: 105
[ Edited ]
Harry
Community Manager
Have you selected the bit file while programming the FPGA?
 Download the bitstream to the board by selecting Xilinx Tools > Program FPGA.
It should look something like below.
Thanks for all of you.I solve this problem,but i meet another one!
 * Empty C++ Application
#include "mb_interface.h"
#include "xparameters.h"
#include "xuartlite.h"
#include "xuartlite_l.h"
#include "xintc.h"
#include "xintc_l.h"
#include "xgpio.h"
//#include "stdio.h"
int main()
	  int i,j,k;
	  bool flag=0;
	  u8 sdata[8]={97,98,99,100,101,102,103,104};
	//print("Enter the main function ...\r\n");
	//u8 data2;
	XUartLite RS232;
	XUartLite_Initialize(&RS232,  XPAR_RS232_UART_1_DEVICE_ID);
	XGpio LEDS;
	XGpio_Initialize(&LEDS,XPAR_LEDS_8BIT_DEVICE_ID);
	XGpio_SetDataDirection(&LEDS,1,0x0);
    while(1)
    	  for(i=0;i<8;i++)
    		  XUartLite_SendByte(XPAR_RS232_UART_1_BASEADDR,sdata[i]);
    		  for(j=0;j<1000;j++)
    		       for(k=0;k<5000;k++)
    		    if(flag==0)
    		      XGpio_DiscreteWrite(&LEDS,1,0xffffffff);
    		    else XGpio_DiscreteWrite(&LEDS,1,0x00000000);
    		      flag = !flag;
	return 0;
 this is the code, and i use led to indicate the program whether or not  running on board. if leds blink on board,it should be running.
this main() only one function,send data to PC forever.But in PC,I recv nothing by use hyper terminal
Kudos: 106
Solutions: 105
Hi zgw12371q,
I have one suggestion for you. Please create new thread for your query otherwise your query can be missed by us. If you will create new thread it will help each one to answer and understand correctly.
Harry
I have the same SDK error. Can you tell me how you fixed this?
Thanks!
hello
can you pl tell me how you solved that problem, in my sdk binaries or elf file is not generated
version 2016.1
please help me , .elf is not generated at all , after compilation arm v7 gcc
