Visitor glathe1851
ZC702 SDK 2013.4 and LIBXILFFS
My question comes down to this:  So, how can I create a standalone C++ project which has access to the fully functional glory of the XILFFS library?
I have part of it worked around, but am having to defeat auto-generated files along the way:
I am attempting to create a standalone application which logs information to the SD memory device, which it also boots from, significant elements of the project are in C++ and it is undesirable to port to C.
This is using a ZC702, and the 2013.4 SDK.
I created a standalone project using C++ and creating it's own BSP, but I am running into 2 problems:
I can work around the first, described here, but cannot defeat the second problem further below.
Any suggestions for solving these would be appreciated.
The first problem occurs when I change the BSP properties to include LIBXILFFS
This breaks the linker script for the C++ project in the following way:
-- Before including the library my objs.mk file looks like this:
LIBS := -Wl,--start-group,-lxil,-lgcc,-lc,-lstdc++,--end-group
-- After including the library it looks like this (and breaks the build due to references to unresolved externals)
LIBS := -Wl,--start-group,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilffs,-lxil,-lgcc,-lc,--end-group
I can work around the project by restoring the objs.mk file to it's former glory, adding the ,-lxilffs item to the list.
I think this is an eclipse customization issue, but I can work around this one.
The problem I cannot find a way to defeat is that I want to be able to use the full features of xilffs.
So, I edit the settings in ffconf.h (in cilffs_v1_00_a/src/include) changing:
FS_TINY to 0 and FS_MINIMIZE to 0
But the library does not rebuild after saving those changes.
The only way I have found to get the library to rebuild is to do a clean build...
Except that the clean build reconstructs the library source, deleting my changes and defeating my goals.
The all-clean build also breaks the linker script again, but that is relatively easy to restore...
