Observer jblock
Zynq 7000 SPI Master Command Sequence in UG585
The example "Master Mode Data Transfer" appears to have the order swapped for the controller enable and the Chip Select (UG585 17.3.3 steps 3 & 4). If the Clk line does not have a pull-up (as is typically the case) the clock may drift low becasue the MIO Clk pin is a tri-state pin. This causes an erroneous rising Clk edge to the slave when enabled. The scope screenshot below represents this command sequence. The green is the clock (which has drifted low) and the yellow is the Chip Select. The result is the interface does not function correctly. If the controller is enabled first, the Clk is driven (and correctly high) when Chip Select is asserted so there is no "extra" rising edge and the interface works properly. Does the UG assume there is an external pull-up on Clk (not mentioned anywhere) or is the sequence incorrect?
The setup used was the most simple case. SPI on MIO, single slave, no other masters, slave is Mode 3.
Re: Zynq 7000 SPI Master Command Sequence in UG585
Hi @jblock ,
Step 3 and 4 are swapped.
Controller should be enabled followed by slave selection.
Praveen
Hi @jblock ,
We recommend the pull-up for SPI in XMP277 schematic checklist not in user guide.
PS_SPI_pull-up.jpgZynq-7000 PS SPI pull up recommendation
Praveen
Observer jblock
Hello Praveen,
The problem is the clock and it is the one signal where a pull-up is not recommended.
Hi @jblock ,
Praveen
