Visitor samuele.m
Zynq 7000 bare metal AMP syncronization
Hello everyone,
we are writing two applications that shall run on both cores of Zynq (we're testing them on the ZC702 evaluation board); the applications need to be synchronized, so we've written lock/unlock routines using ldrex/strex ARM instructions (following directions in "ARM Synchronization Primitives" article), but something weird happens: while core0 quietly locks and unlocks, in core1 strex always fails; we tried using an address in OCM and one in RAM but nothing changes: strex always returns 1. I can't figure out where the problem is: I suspect something's wrong with memory attributes (they have been set to 0x14de2) but I'm not really sure... Can somebody lend a hand?
This is the code we use for lock/unlock:
lock_mutex:
/* lock_mutex */
	dmb ish
/* Declare for use from C as extern void lock_mutex(void * mutex) */
	ldr r1, =locked
_lbl1:
    ldrex r2, [r0]
	cmp r2, r1				// test if mutex is locked or unlocked
	beq _lbl2 				// if locked - wait for it to be released, from _lbl2
	strexne r2, r1, [r0]	// not locked, attempt to lock it
	cmpne r2, #1 			// check if store-exclusive failed
	beq _lbl1 				// failed - retry from _lbl1
	// lock acquired
	dmb 					// required before accessing protected resource
	bx lr
_lbl2: 						// take appropriate action while waiting for mutex to become unlocked
	wfe
	b _lbl1  				// retry from _lbl1
	.global unlock_mutex
unlock_mutex:
// unlock_mutex
// Declare for use from C as extern void unlock_mutex(void * mutex)
	ldr r1, =unlocked
	dmb 			// required before releasing protected resource
	str r1, [r0] 	// unlock mutex
	clrex
	dsb
	sev
	bx lr
Thank you very much!
Teacher muzaffer
Re: Zynq 7000 bare metal AMP syncronization
Checkout this post:
http://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/an-exclusive-access-ldrex-strex-question/td-p/404397
Teacher muzaffer
Checkout this post:
Newbie bornetr
I do have the same issue and already had a look at the suggested post but not sure I interpreted it correctly. The phrasing is a bit confused...
How did you finally configure your memory attributes and the L2 Auxiliary Control Register ? Can you provide the values you used in your working setup ?
Kind regards
Visitor samuele.m
Hi, after an initial moment of enthusiasm we ran into problems that seemed to be solved with a weird memory attributes setting... I explained the situation in the same discussion cited above.
