Zynq CDMA problem
I am porting an application from microblaze and Kintex to Zynq and Cortex A9.
I was transmitting a large buffer of data ( 307200 KByte) by ethernet. Microblaze receive several packets. Every time it receives a packet it transfers this packet using CDMA in another memory buffer. For every CDMA transfer I did:
1) flush source memory range
2) flush destination memory range
3) execute an mbar(0)
4) Start CDMA and wait untili it is finished
5) invalidate destination memory range to force loading  updated data from DDR to cache when data are used.
All is working good.
Now I have ported this on Zynq, and I have not an mbar instructions, then I do this:
3) Start CDMA and wait untili it is finished
At the end of all I have some byte in destination memory that are not equal to source data buffer, in random position.
Does it exist an equivalent mbar instruction for Cortex A9?
Begos
Teacher muzaffer
Re: Zynq CDMA problem
cortex a9 has a memory barrier instruction dmb (data memory barrier).
Hi Muzaffer,
many thanks for information.
Begos
