Zynq DDR ECC error count register never incremented
Re: Zynq DDR ECC error count register never incremented
I have asked the case be escalated on your behalf.
You could have asked for escalation yourself.
I will let you know if I hear anything.
Austin Lesea
Principal Engineer
Xilinx San Jose
Thank-you Austin.
Could you confirm that the Zync actually implements ECC and not just Parity Error detection?
The TRM says the Zynq implements an ARM cortex-A9 but looking at the ARM TRM shows only the A8 with an ECC option where as the A9 only has Parity error dection.
e.g.
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0414i/index.html - Cortex-A8 TRM
  - see Section "8.7 Parity and error correction code" - says it can be implemented with ECC support.
  **BUT**
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0388i/index.html Cortex-A9 TRM Section 7.7 "Parity error support" which only talks about an optional parity error support but no mention of Error Correction.
So if the Zynq does support it perhaps this is a Xilinx enhancement, which would mean the ARM guys are not going to
be helpful, you would really need to talk with an internal engineer.
Andrew
ECC on DDR DRAM,
Parity on L1, L2 and OCM.
Austin Lesea
Principal Engineer
Xilinx San Jose
Thanks - I think that ECC is Xilinx addition.
If you interested I added a suggestion to the Web Case of how the ECC could be tested once we get the ECC error stats register incrementing. Jangi has raised some sort of CR against it so perhaps we might get this working.
Jangi on the Web case they are looking at building some code to test this - will keep posted if they
make a break through  - which would be great for me.
From the Web case I understand there is an issue and they suggest closing the Web case and waiting for the CR.
Unfortunately I still don't know any details of what the CR is - software/hardware/configuration/???
Perhaps they think I know or perhaps it's secret - I have asked perhaps I might be lucky and be told something to help me ... one day... :-(
Unacceptable,
Request that it be escalated.  Tell them you need an answer.  You are the customer, and you are always right.  If you let them close it, they are "off the hook."
There are no "secrets,"  if it is broken, we have to post an errata, and tell folks when it will be fixed.
I will ping some folks again.  It should not be this difficult to use an error counter....
Austin Lesea
Principal Engineer
Xilinx San Jose
Follow below steps.
  • Initialize DDR with ECC from CPU0.
  • Issue read to couple of DDR locations(make sure that requests should reach DDR, these requests should miss the L2 Cache)
  • Read ECC counters from CPU1, since you can't do anything with CPU0.
I am being told this works.  An example with code is something you have requested from support, and that may be what is taking the time.  There is no technical issue that anyone is aware of (among the folks who know -- i.e. the designers/verifiers).
Austin Lesea
Principal Engineer
Xilinx San Jose
Thanks for this Austin, I only just noticed your reply (was expecting a web case response first).
I will have to look at this next week.
I think I am missing a key part of the puzzle - likely this distinction between reads from one CPU versus another or probably something to do with the L2 cache (which has another ECC level) getting in the way or something.
Perhaps disabling the L2 cache could avoid the issue. Not sure how to read from one CPU versus another via the kernel (runs both CPUs) or uboot (only runs one CPU) .
Andrew
a,
Stay tuned!  It appears that all my questions about this may have uncovered an issue!  They are now really looking at it in the design team (the folks responsible for the design).  Seems they were convinced it had all been checked out (box checked in the verification spreadsheet as 'done').  But, when they go to look at exactly what was checked out, they try to repeat it, and it doesn't work....
So, I stand by everything I have already posted (as they have told me that is how you do it).  Now it is a questions of them doing it again, and telling us how they did it.
And, do not let the webcase folks off the hook, either.
Austin Lesea
Principal Engineer
Xilinx San Jose
