Zynq UltraScale+ Shutdown Routine
Hi All,
I want to power off linux and than power down everything else on the Zynq chip.
I have a push button interrupt controller connected to PS_MIO (this GPIO is avaliable for PMU)
I want to use XPm_SystemShutdown or XPm_SelfSuspend from:
https://www.xilinx.com/support/documentation/user_guides/ug1199-zynq-power-management.pdf
I am not sure what module should run this function.
Is it RPU or PMU?
What is a safe way to turn off linux?
Do think that im using correct approach to the problem?
Anton
Re: Zynq UltraScale+ Shutdown Routine
Hi u6113500@anu.edu.au ,
This page https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842181/Zynq+UltraScale+MPSoC+Power+Off+Suspend would help you with shutdown, suspend per domain wise sequence.
Praveen
Praveen
