how to change interrupt priority in sdk?
I need to use several interrupts in SDK,some from PS the other from PL , so I need to change priority of some interrupts but i donot know what the priority they are and how to change their priorities. Is there some refferenced designs?
thanks very much.
Community Manager
Community Manager
Re: how to change interrupt priority in sdk?
Please find it attached.
Did you get a chance to look at the reference design available at http://www.xilinx.com/support/answers/50572.html?
I think this can be modified to match your requirement
--HS
Thanks for you reply.I saw the linker as you told me  but i can find only one interrupt source which is  timer interrupt .My question is that if i wanna use several interrupts which produced by PL and PS hwo do i know their priority and change the priority of them  in SDK?
Community Manager
Community Manager
If you are talking about nested interrupts then you can check the following AR:
http://www.xilinx.com/support/answers/54128.htm
Also, you may want to check-out this example design:
Sikta
thanks for your reply ,i saw the link you told me but i cannot find the file named nested_interrupt_demo.c ,so what should i do ?
Community Manager
Community Manager
