Newbie jasongutel
making u-boot.elf for ZedBoard
I am attempting to make the u-boot.elf file for the ZedBoard following this guide. I am running into an error though that I am not sure how to resolve. Has anyone seen this before?
$ git clone https://github.com/Xilinx/u-boot-xlnx.git
Cloning into 'u-boot-xlnx'...
remote: Counting objects: 339952, done.
remote: Total 339952 (delta 0), reused 0 (delta 0), pack-reused 339952
Receiving objects: 100% (339952/339952), 88.98 MiB | 22.22 MiB/s, done.
Resolving deltas: 100% (268194/268194), done.
Checking connectivity... done.
$ cd ./u-boot-xlnx/
$ make zynq_zed_config
# configuration written to .config
$ make
scripts/kconfig/conf --silentoldconfig Kconfig
  CHK     include/config.h
  UPD     include/config.h
  GEN     include/autoconf.mk
  GEN     include/autoconf.mk.dep
  GEN     spl/include/autoconf.mk
  CHK     include/config/uboot.release
  UPD     include/config/uboot.release
  CHK     include/generated/version_autogenerated.h
  UPD     include/generated/version_autogenerated.h
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  CC      lib/asm-offsets.s
lib/asm-offsets.c:1:0: error: bad value (armv5) for -march= switch
Kbuild:43: recipe for target 'lib/asm-offsets.s' failed
make[1]: *** [lib/asm-offsets.s] Error 1
Makefile:1228: recipe for target 'prepare0' failed
make: *** [prepare0] Error 2
Newbie jasongutel
Re: making u-boot.elf for ZedBoard
Resolved. Wish I could delete this post :)
sudo apt-get install arm-linux-gnueabi
sudo apt-get install device-tree-overlay
export CROSS_COMPILE=arm-linux-gnueabi-
export ARCH=arm
cd ~/gits/u-boot-xlnx
make
Newbie jasongutel
Looks like I need to set the cross-compiler...
I installed gcc-arm-linux-gnueabi
then tried this:
$ export CROSS_COMPILE=gcc-arm-linux-gnueabi
$ make
make: gcc-arm-linux-gnueabigcc: Command not found
/bin/sh: 1: gcc-arm-linux-gnueabigcc: not found
dirname: missing operand
Try 'dirname --help' for more information.
/bin/sh: 1: gcc-arm-linux-gnueabild: not found
make[1]: *** [lib/asm-offsets.s] Error 127
I'm obviously configuring this wrong. Which package do I need and how do I set the CC? Thanks!!
Newbie jasongutel
export ARCH=arm
make
Please don't delete as the question & answer is useful.
I only delete posts I self-answered and when I felt like a fool for posting silly question.
Observer eneserdin
FYI  on Ubuntu 16.04 i installed "gcc-arm-linux-gnueabi"
Observer shustik
I have the same problem, the same error.
Please, could you explain me how to install cross_compiler?
Unfortunately
export CROSS_COMPILE...
export ARCH=arm
doesn't help...
Newbie 2p718
It is part of the Xilinx SDK -- so install that.
The cross compiler has changed.  It is now:
export CROSS_COMPILE=arm-linux-gnueabihf-
source /opt/Xilinx/SDK/2017.2/settings64.sh
Visitor nattaponj
nattaponj@debian:~/zybo_debian/sw/u-boot-xlnx$ git checkout xilinx-v2015.4
Previous HEAD position was 0b94ce5ed4... ARM64: zynqmp: usb1 on zcu100 is not peripheral
HEAD is now at 4942ae4d03... zynqmp: dt: DC1: making compatible string generic for qspi node
nattaponj@debian:~/zybo_debian/sw/u-boot-xlnx$ source /opt/Xilinx/Vivado/2015.4/settings64.sh
nattaponj@debian:~/zybo_debian/sw/u-boot-xlnx$ export CROSS_COMPILE=arm-xilinx-linux-gnueabi-
nattaponj@debian:~/zybo_debian/sw/u-boot-xlnx$ export ARCH=arm
nattaponj@debian:~/zybo_debian/sw/u-boot-xlnx$ make zynq_zybo_defconfig
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
nattaponj@debian:~/zybo_debian/sw/u-boot-xlnx$ sudo make
In file included from include/linux/compiler.h:54:0,
                 from include/linux/byteorder/little_endian.h:12,
                 from ./arch/arm/include/asm/byteorder.h:29,
                 from include/compiler.h:125,
                 from include/image.h:19,
                 from ./include/common.h:82:
include/linux/compiler-gcc.h:114:30: fatal error: linux/compiler-gcc6.h: No such file or directory
 #include gcc_header(__GNUC__)
compilation terminated.
scripts/Makefile.autoconf:72: recipe for target 'include/autoconf.mk' failed
make[1]: *** [include/autoconf.mk] Error 1
make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'.  Stop.
I have followed the same steps as you mentioned. Still i am facing the same error (cc1: error: bad value (‘armv5’) for ‘-march=’ switch)
Here is the log from whatever your suggested commands.
praveen@praveen-VirtualBox:~$ sudo apt-get install arm-linux-gnueabi
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package arm-linux-gnueabi
praveen@praveen-VirtualBox:~$ sudo apt-get install device-tree-overlay
E: Unable to locate package device-tree-overlay
praveen@praveen-VirtualBox:~$ export CROSS_COMPILER=arm-linux-gnueabi-
praveen@praveen-VirtualBox:~$ export ARCH=arm
praveen@praveen-VirtualBox:~$ cd u-boot-xlnx/
praveen@praveen-VirtualBox:~/u-boot-xlnx$ make zynq_zed_config
  CFG     u-boot.cfg
  CFG     spl/u-boot.cfg
cc1: note: valid arguments to ‘-march=’ switch are: nocona core2 nehalem corei7 westmere sandybridge corei7-avx ivybridge core-avx-i haswell core-avx2 broadwell skylake skylake-avx512 bonnell atom silvermont slm knl x86-64 eden-x2 nano nano-1000 nano-2000 nano-3000 nano-x2 eden-x4 nano-x4 k8 k8-sse3 opteron opteron-sse3 athlon64 athlon64-sse3 athlon-fx amdfam10 barcelona bdver1 bdver2 bdver3 bdver4 znver1 btver1 btver2
Makefile:1337: recipe for target 'prepare0' failed
Please let me know if i done anything wrong and also please suggest if i need to do any other configuration changes.
Currently i bought Zynq7Z020 board and we are planning to boot using linux ubuntu.
Praveen.
Visitor meysam.gdz
Hi, Sorry for bothering, Could you actually solve your problem ? I am facing the same problem, whetever solution that find in forums are not working for me. I would be thankful if you could let me know what you did to solve the problem. Thank you.
Use the below command to build.
sudo make ARCH=arm CROSS_COMPILE=arm-Linux-gnueabi-
Praveen Kumar.
