Observer fkharrat
problem ov7670 with vdma
I work on a project : display a video capted by OV7670 on a VGA screen via a VDMA implementer for the zedboard (vivado 2013.4), i use the project of Lauri http://lauri.xn--vsandi-pxa.com/cache/c9e26b07f5904f12928a883f1a914073.png
i can't integrete the axi_subset_converter IP in my design, when i used i got many error.
So i changed the ov7670_axi_stream_captor IP to a other IP with 24 bit output data (to 24-bit RGB (8:8:8)), but i got a false image,
my design :
OV7670_axi_stream_captor_24 => VDMA ( 24 bit input / 24 bit output ) => Video out ( RGB , 8bit) => rgbtovga (24 bit input)
I can't fixed the source of this error, it's problem of color (rgbtovga IP) or problem of I2C ( ov7670_controller ) ?
Re: problem ov7670 with vdma
This could be any number of things, but it doesn't look like anything specifically with the VDMA.
I'd put a TPG before (and maybe after) the VDMA and see if the output path looks right. I'd also start probing data at different points and see where it's going wrong.
www.xilinx.com
Observer fkharrat
Yes i used the tpg Ip and it's working.
but i doubt that the problem is around the convertesion 32bit to 24 bit :
***i used before a VDMA with 32bit input and 24bit output => i got a false image
(my IP ov7670_capteur have a 32bit output : RGBA 8888 / and my IP ov7670_vga have a 24bit input : RGB 888 )
*** and when i used a other Ip ov7670_capteur with   24bit output ( RGB 8888) i got also false image =>
 can you tell me when i change the ip ov7670_capteur  i shoud changed the controleur of I2C IP ??
*** and when i used a AXI_subset_converter , i got many error in vivado
What errors are you getting with the subset converter. I'd pull up the post-synthe schematic and make sure you're picking off the right bits.
Beyond that, ILAs at various nodes in the datapath.
www.xilinx.com
