s_axis_tdata width of AXI4-Stream switch
Hi all,
I'm using an AXI4-Stream Swithc core. and there are two slave interfaces and one master interface.
I set TDATA width to 1 byte. and master interface's tdata width is 8-bit. But each slave interface's tdata width is 16-bit.
When I set them to 2 byte, slave's tdata is 32-bit and master is 16-bit. This does not make a sense.
I think both slave and master's tdata width should be same.
Why slaves' tdata width are twice than master's one?
Community Manager
Community Manager
Re: s_axis_tdata width of AXI4-Stream switch
This is expected when using the crossbar/switch cores. All the signals for each channel are concatenated together. The customer should use the AXI Stream Interconnect instead of the Switch to get the normal situation where the channels are all broken apart. The Interconnect also has all the additional features (resizer, fifos, register slices, etc) that the Switch lacks.
slave _tdata = master_tdata * number of slaves and master_tdata = slave_tdata * number of masters
It is in simple numerical order. In other words: tdata[15:0] -> slave0, tdata[31:16] -> slave1, ... and so on
If I select 2 slaves and 1 master with 1 byte as tdata width, IP block diagram shows s0_axis_tdata(15:0) , s1_axis_tdata(15:0) and master M00_axis_tdata(7:0)
But the wrapper has only s_axis_tdata(15:0)
Check the wrapper also.
Sikta
Community Manager
Community Manager
Sikta
