Visitor auto
vivado logic analyzer
Hi, I'm a newbie to fpga's and vivado. How to install 30 day trial of logic analyzer in ubuntu . I'm running vivado webpack and sdk on my  ubuntu 14.04 laptop.
Re: vivado logic analyzer
You can check the installation flow described at
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf (page #16)
You need to install Free 30-day Evaluation version in order to use Logic Analyzer feature. Vivado WebPack won't support it.
http://www.xilinx.com/products/design-tools/vivado/vivado-webpack.html
Ashish
@auto
You must have permanent or evaluation license to use logic analyzer.
Anusheel
Helpful answer -> Give Kudos
Visitor auto
HI, Thamks for the reply. I followed both the links. I followed both the links neither mentioned how to install Logic analyzer. Does it have a seperate setup to install logic analyzer and activate 30 day trial. The setup I downloaded doesn't have install popup for logic analyzer. Please explain in detail.
Logic Analyzer comes with Vivado Design Suite. Download IDE trail version and you get logic analyzer as well.
Praveen
