Observer jacobfeder
xuart_ps_intr_example.c code not working
Can someone confirm? I have tried it with a clean project and it seems that the interrupt handler function never gets called and the program gets stuck in an infinite loop.
Observer jacobfeder
Re: xuart_ps_intr_example.c code not working
I believe I found the problem. On line 93:
#define UART_INT_IRQ_ID XPAR_XUARTPS_1_INTR
should be:
#define UART_INT_IRQ_ID XPAR_XUARTPS_0_INTR
The example was using the the interrupt id of UARTPS_1 but the device id of UARTPS_0
Observer jacobfeder
should be:
