zynq axi fifo tuftorial
I'm looking for tutorial for handling about AXI FIFO.
I'm not famillar with zynq system. Is there any tutorial ZYNQ AXI4LITE FIFO?
Re: zynq axi fifo tuftorial
check product guide
http://www.xilinx.com/support/documentation/ip_documentation/axi_fifo_mm_s/v4_1/pg080-axi-fifo-mm-s.pdf
http://www.xilinx.com/products/intellectual-property/axi_fifo.html
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Best-Method-for-AXI-Lite-interface-to-PL-FIFO-interface/td-p/563558
Thanks and Regards
Balkrishan
