Voyager
Voyager
zynq ultrascale+ : custom IP intrrupt handleing
I have a user custom IP, which generate interrupt. This I directly connected to PS IP (pl_ps_irq0).
I would like to know how to use this interrupt in PS. Do I have write driver for interrupt controll or I must use AXI interrupt controller from Xilinx ? Which is recommented way to implement interrupt from custom IP? or there is other ways to use interrupts?
Thank you
Kind regards
Voyager
Voyager
Re: zynq ultrascale+ : custom IP intrrupt handleing
I am able to write driver and enable interrupt.
I followed the video
https://youtu.be/o8JlJGbkX_s
Notice: Time Marker ~26:45, use the modified VHDL code for 0x05F5E100 (Shown a few moments before) and ignore the VHDL you see there. This video is targeted for the Zybo board for the development of a custom IP in the programmable logic which will generate an interrupt to the Zynq processing ...
You can write your own driver. Or, you can use the UIO driver. Please see the wiki below for help using the UIO on ZCU102 (Zynq Ultrascale)
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842490/Testing+UIO+with+Interrupt+on+Zynq+Ultrascale
Voyager
Voyager
