1000 base pcs/pma ip
I am trying to do 1g ethernet with 1000base x pcs/pma ip and sfp transeivers.when i created the soft ip.In soft ip core directory there are some file ,example design.Is it the top module for the design or how to use those set of .v codes plz help me...
Hi @harik0412 ,
After generating the core, please right click on the IP in Vivado and then click on "Open Example Design". You should have an example design now with hierachical files. Feel free to look into and examie them to get started.
Is it ISE?
Please just add all the source codes generated in the example into a new ISE project. Then this new project can do simulation or Implement directly.
